Built-in speakers mean this curved soundbar can deliver powerful, pure sound. Tweeters provide crisp and clear high tones while mid-range drivers deliver mid-range frequencies that are warm and detailed.
Connect your soundbar to your TV without wires and enjoy superb, powerful sound that brings programs, movies and music to life.
Enhanced surround sound from a wider range of listening positions
Surround sound expansion expands the listening area sideways and up so it is more realistic and coming directly from the screen. You can enjoy great sound with truly immersive surround effects.
Bluetooth connectivity
You can power on your audio system and control it from your smartphone with Bluetooth. After an initial pairing, you can quickly find the devices you want, wake them up, and stream your music.
Samsung HW-J6001R - sound bar system - for home theatre - wireless
Sound bar system - for home theatre - 2.1-channel
Media Content Source
USB-host
System Components
Subwoofer, sound bar
Speaker Type
Active
Nominal Output Power (Total)
300 Watt
Amplifier
Integrated
Bluetooth
Audio Formats
WAV, WMA, AAC, MP3, FLAC, OGG
Speaker System Details
1 x sound bar 132 Watt 4 Ohm , 1 x subwoofer 168 Watt 3 Ohm
Speaker Details
Sound bar - surround x 6 - 22 Watt - at 1 kHz - 10% THD - 4 Ohm - active , Speaker - subwoofer - 168 Watt - at 100 Hz - 10% THD - 3 Ohm - active
Silver
Built-in Decoders
Dolby Digital, DTS decoder, DTS Digital Surround
Sound Effects
Surround Sound Expansion
Power Options
Auto power on/off
Environmental Standards
ENERGY STAR Qualified
USB-host
Enclosure Colour
Silver
Design Features
Curved
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
300 Watt
Amplifier
Integrated
Sound Effects
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Recommended Placing
Wall-mountable, under-the-TV
Built-in Decoders
Audio Formats
Controls
Input selector, power on/off, volume
Speakers Included
1 x sound bar - 132 Watt - 4 Ohm - wireless , 1 x subwoofer - 168 Watt - 3 Ohm - wireless
Speaker Details
Sound bar - surround x 6 - 22 Watt - at 1 kHz CFR - 10% THD - 4 Ohm - active , Speaker - subwoofer - 168 Watt - at 100 Hz CFR - 10% THD - 3 Ohm - active
Driver Details
Subwoofer: subwoofer driver - 7"
Connector Type
HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , Digital audio input (optical) (TOS Link) , USB (4 PIN USB Type A)
AC power adaptor, remote control, power cable, wall mount, 2 mounting brackets
Sustainability Information
ENERGY STAR Certified
Power Source
AC power adapter
Options
Auto power on/off
Dimensions (WxDxH) / Weight Details
Sound bar: 1.078 m x 12.9 cm x 4.75 cm / 2.7 kg , Subwoofer: 45.2 cm x 15.4 cm x 33.5 cm / 6.8 kg
