If you need to get the job done, the SP 150 is the printer for you. Designed to make you more productive, its simple installation process and 22ppm output means you can enjoy its reliability, intuitive operation and sleek design, almost straight out-of-the-box.
Its simplicity means you can get on with what you need to do, safe in the knowledge that all your printing needs are taken care of. No matter if it's home or small business print requirements.
