Quicklinx: | C9K1WS00 |
Mfr#: | 906230 |
Just because your budget is tight or your office is limited on space, it shouldn't limit what you can do. Use the Ricoh SP 4510SF to perform a wider range of everyday document management tasks - including printing, scanning, faxing and copying quickly - so you can move from one project to the next without missing a beat. Place the compact MFP nearly anywhere, even on your desk, to save space while you save time.
Customize the device to accommodate personal preferences. Take advantage of security controls to protect your information. Access administrative controls remotely to keep the SP 4510SF running efficiently - whether you add it to an integrated Ricoh Managed Document Services (MDS) portfolio or use it as your primary device.
