The SP 213SFw combines high productivity with ease of use in a compact package. A fast print speed, colour scanning and high speed G3 faxing enhance small/home office performance. This MFP is also very easy to use via the user-friendly 4-line LCD panel and everything can be done from the front of the device. ID Card Copy is another time-saving feature allowing you to copy both sides of an ID card onto one side of paper. You can also send print data directly from a smart device such as a smartphone or tablet. To top it off, paperless fax reception, manual double-sided printing and a high-yield, all-in-one print cartridge reduce your overall costs.
- Fast: 22 pages per minute
- High resolution: 1,200 x 600 dpi
- Effortless printing with Ricoh’s Smart Device Print & Scan
- Mobile app
- ID Card Copy & colour scanning
- Manual double-sided printing & PCL support
- Wireless 4-in-1 MFP
- B&W printing and copying, colour scanning, G3 fax
- WiFi and USB 2.0 interfaces
- Fast 27 second warm-up
- First print delivered in 10 seconds
- Scan in high-resolution colour
