Powered by the Intel dual-core processor and large memory, it delivers high performance at a throughput rate of 250 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 4-bay VS-4116 Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-4116 Pro+ can support up to 16 TB of storage capacity, with 4 TB on each hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard, Sanyo Denki system fan, and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-4116 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
