Quicklinx: | B53XWS00 |
Mfr#: | VS-4112U-RP-PRO+-UK |
Powered by the Intel dual-core processor and large capacity memory, it delivers high performance at a throughput rate of 250 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 4-bay rackmount VS-4112U-RP Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-4112U-RP Pro+ can support large storage capacity, with hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The VS-4112U-RP Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
