Quicklinx: | B546WS00 |
Mfr#: | VS-12156U-RP-PRO+-UK |
The QNAP VS-12156U-RP Pro+ VioStor NVR (Network Video Recorder) is the high-end 2U chassis network surveillance server which supports high quality real-time video/audio monitoring, megapixel recording (up to 10-megapixel), and playback of multiple IP cameras. The VioStor VS-12156U-RP Pro+ can simultaneously handle inputs from up to 56-megapixel cameras. Featuring a powerful quad-core Intel Core i5 processor and DDR3 memory, this enterprise-grade NVR delivers high performance with throughput of 450 Mbps for recording and smooth playback of multiple megapixel cameras. Moreover, the HDMI output and hardware decoder of VS-12156U-RP Pro+ provide the ability to deliver up to 300 fps Full HD local display.
The VioStor VS-12156U-RP Pro+ supports large storage capacity, which makes it proficient for continuous recording of high-resolution video.
The Linux-based VioStor VS-12156U-RP Pro+ enables quick and easy deployment of multiple NVRs. It is designed with the user in mind, offering simple and intuitive setup in six steps. Coupled with powerful performance and stability, this solution is tailor-made for enterprise surveillance needs.
