Whether you're warming up or winding down, move freely with BackBeat FIT 500 Series wireless sport headphones. Enjoy deep, rich sound, sweat-resistant nano-coating by P2i and a lightweight design for comfortable wearing all day.
From the locker room to the lecture hall, you're always on the move. Listen for up to 18 hours on a single charge, then use DeepSleep mode to conserve power when your headphones aren't in use. Can't find a place to recharge? Listen uninterrupted with the 3.5 mm backup jack.
Sweat it out
Constantly on the move? P2i military-grade nano-coating protects the headphones against sweat, moisture and spills, so they're durable enough to withstand rainy commutes and gym sessions.
Bring your music to life
Don't just hear your favorite tracks, feel them. 40 mm drivers and advanced acoustic technology deliver audio balance and deep, rich sound - whether you're hitting the weights or the books.
Poly - Plantronics Backbeat FIT 500 - headphones with mic
Headphones - Bluetooth - wireless - 3.5 mm jack
Recommended Use
Portable electronics
Style
Sports
Teal
Headphones Form Factor
On-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Controls
Volume, power on/off, answer/end, next/previous track
Series
500 Series
Style
Sports
Teal
Earpad Material
Memory foam
Recommended Use
Protection
Moisture-resistant, sweat-resistant
Max Operating Distance
10 m
Audio Output
On-ear
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Diaphragm
40 mm
Microphone
Built-in
Remote Control
Controls
