Studies have shown that just as ultra-violet rays can cause eye damage, blue light rays from LED displays can cause damage eye damage and affect vision over time. SoftBlue LED technology uses a smart technology to reduce the harmful blue light waves without affecting the color or image of the display. SoftBlue LED technology is certified by international testing organizations SGS Labs and TUV Rheinland to reduce blue light and protect your eyes.
IPS-ADS technology
IPS-ADS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS-ADS displays give you remarkably crisp images with vivid colors, making it ideal not only for photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
16:9 Full HD display
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
SmartImage Lite
SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
SmartContrast
SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
Modern touch controls
Touch controls are intelligent, touch sensitive icons that replace protruding buttons that lets the user adjust the monitor to their requirement. Responding to your lightest touch, Touch control gives the monitor a modern feel.
Philips E-line 277E6EDAD - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey), 14 ms (typical)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, MHL
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
Glossy cherry black
64 cm x 23.5 cm x 47.8 cm
5.42 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, WEEE, SGS, cETLus, ISO9241-307
Display Type
Energy Class
Class A
41 kWh
Diagonal Size
27"
Panel Type
ADS-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Power Supply
External
Input Voltage
28 W
Power Consumption (Typical)
18.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / Windows 8
Dimensions & Weight Details
With stand - width: 64 cm - depth: 23.5 cm - height: 47.8 cm - weight: 5.42 kg , Without stand - width: 64 cm - depth: 4.8 cm - height: 39.4 cm - weight: 5.17 kg
