This attractive Philips display with ultra narrow bezel and AHIPS screen gives you awesome, vibrant color images. Mobile HD link allows you to connect your smartphone.
SmartImage Lite for an enhanced LCD viewing experience
SmartImage Lite is an exclusive, leading edge Philips technology that analyses the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, colour saturation and sharpness of images and videos for ultimate display performance - all in real time with the press of a single button.
HDMI-ready for Full HD entertainment
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
TrueVision ensures lab quality images
TrueVision is a proprietary Philips technology that uses an advanced algorithm for testing and aligning monitor display, which gives you the ultimate display performance. Philips ensures that TrueVision monitors leave the factory fine-tuned with this process giving you consistent colour and picture quality.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
MHL technology for enjoying mobile content on a big screen
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway.
Minimalistic looks with Ultra-Narrow Bezel
Utilising the latest technology panels, the new Philips displays are designed with a minimalistic approach by limiting the outer bezel thickness to about 2.5 mm. Combined with an in-panel black matrix strip of around 9 mm, the overall bezel dimensions are reduced significantly, minimising distractions and maximising viewing size. Especially suited to multi-display or tiling setups like gaming, graphics design and professional applications, the Ultra-narrow bezel display gives you the feeling of using one large display.
AH-IPS display gives awesome images with wide viewing angles
AH-IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, AH-IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
Philips 234E5QHAW - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
Glossy white
53.2 cm x 21.3 cm x 41.4 cm
3.46 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, BSMI, GOST, SASO, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE
3-year warranty
Display Type
Energy Class
Class B
39 kWh
Diagonal Size
23"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, HDCP, SmartImage Lite, SmartResponse, SmartContrast, TrueVision, Touch Control, Mobile High-Definition Link (MHL)
Power Supply
External
Input Voltage
27 W
Power Consumption (Typical)
29.1 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 21.3 cm - height: 41.4 cm - weight: 3.46 kg , Without stand - width: 53.2 cm - depth: 4.5 cm - height: 41.4 cm - weight: 3.11 kg
