The Peerless-AV modular mount line includes a small and easily manageable number of sku's, yet provides a full range of options that can fulfill a vast majority of end-user requirements. Universal components make it quick and easy to design and configure the perfect custom projector mounting solution, ideal for any application. Designed around a 2" (50 mm) diameter extension pole, the line is ideal for projects as well as upgrading existing installations. The MOD-PRSSKIT100 ceiling mount kits include all of the components required to mount a projector from the ceiling. As part of the Peerless-AV modular series, it can be expanded with additional modular accessories to accommodate virtually any custom configuration.
