The LS7200’s low-profile form contains a multi-driver array fed by a slim external amp connected via a single cable, reproducing Dolby Atmos® and DTS:X™ soundtracks with conviction. Effects move from channel to channel, immersing you in multidimensional sound, while music streamed wirelessly with DTS Play-Fi®*1, AirPlay®, or Wi-Fi® has substance that others can’t match. Players connect to the receiver’s four HDMI® inputs and wiring is concealed inside your entertainment unit for a near-invisible install. With a vast choice of entertainment within Onkyo Controller app (including multi-room audio), the LS7200 makes life better with sound tailored to you.
