You can handle any curve that comes your way. Now, so can your phone with Glass Curve Elite. Its full screen adhesive preserves touch sensitivity and ensures that your screen responds to every tap and swipe.
The custom, curved fit of Glass Curve Elite has been specially designed to fit the contours of your screen precisely. And its sleek design is case-friendly. You won't even know it's there - but your phone will.
Shock absorbent layer
A shock-absorbent layer helps prevent the impact of an unexpected drop from shattering your screen.
Precision touch sensitivity
A full screen adhesive solution ensures every inch of your screen responds to your input.
Smooth, tempered glass
Protecting your screen doesn't mean you have to sacrifice its silky look and feel. Smooth, tempered glass feels just like your phone's original screen and provides 100% clarity.
Smudge-resistant finish
Nothing ruins a great Instagram post like a blurry screen. The smudge-resistant surface of the tempered glass wipes cleanly and prevents fingerprints from accumulating.
ZAGG InvisibleShield Glass Curve Elite - screen protector for mobile phone
