The Galaxy Tab1/2 & Galaxy Note 10.1 Enclosure Hero secure mount is the ideal Galaxy Tab security solution for all display settings including education, health-care, corporate, retail and point of sale environments.
The Galaxy Tab1/2 & Galaxy Note 10.1 Enclosure Hero Mount is closed on all sides to provide a tamper-proof security solution. The charging cable is secured within the enclosure with an opening for the wire to allow for mounted charging.
The Galaxy Tab1/2 & Galaxy Note 10.1 Enclosure Hero mount is the perfect solution for corners, bar table tops, under cabinets, or simply where some extra versatility or space is needed. The tension screws allow for precise fluid or locked movement and the 90 degree rotation makes it the perfect choice for both landscape and portrait orientation modes.
