IPS (In-Plane Switching) technology highlights the performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
On-Screen control
On-Screen control puts a host of essential settings into a handy window for quick, easy access. Volume, brightness, picture mode presets, Screen Split and more can now be adjusted with just a few clicks of the mouse.
Screen Split
Customize your monitor layout for multitasking with the latest version of LG Screen Split. Resize and display multiple windows at once, with 14 options including four different picture-in-picture (PIP) choices.
Black Stabilizer
Keep visibility even in dark scenes. LG's Black Stabilizer senses dark scenes and helps make it brighter so that you can find the enemies hiding and waiting to attack your player in the dark.
Reader mode
Reducing blue light to help lessen eye fatigue, Reader mode provides optimal condition for reading. With just a click of a mouse, you can more comfortably read your monitor screen.
Sleek design
The panel's slim and sleek design is about form meeting function. The reduction of panel depth adds a sharp, clean look to a workspace at the same time frees up space on your desktop.
ArcLine stand
The sleek design of LG premium monitors is accentuated by the ArcLine stand. The smooth curve of the base provides stability, assuring dependable performance with a touch of elegance.
LG 24MP58VQ-P - LED monitor - Full HD (1080p) - 24"
SUPER Energy Saving Technology, Flicker Safe, Reader Mode, Multilingual On Screen Display, Black Stabilizer, My Display Preset, Sleek Cut Design
55.05 cm x 8.65 cm x 33.21 cm - without stand
2.8 kg
VGA , HDMI , DVI , Headphones
Plug and Play, DDC/CI
Input Voltage
AC 120/230 V
Power Consumption (On mode)
25 W
Power Consumption (Typical)
23 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 55.05 cm - depth: 8.65 cm - height: 33.21 cm - weight: 2.8 kg , With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg
