The Konftel 220 is a user-friendly analog conference phone with the same outstanding audio quality as Konftel's more advanced models. The patented OmniSound HD technology guarantees crystal-clear audio in all directions. The Konftel 220 is designed to help you quickly get started and is easy to use. The five speed dialing keys can be pre-programmed to make it fast and easy to call the most frequently used numbers. Just press one key to launch your meetings! It looks smart on your desktop and in smaller conference rooms. The Konftel 220 is a professional and reliable choice for offices with analog phone systems.
