Kingston's SSDNow mS200 mSATA solid-state drive oers a cost effective performance boost with a dual-drive option that allows room for adding high-capacity storage. Ideal for system builders, OEMs and enthusiasts, the mS200s ruggedly-cool, miniscule form factor is eight times smaller than a traditional 2.5-inch hard drive, making it perfect for notebooks, tablets and Ultrabooks. Available in capacities of up to 480GB, ms200 has a caseless, PCB-only design with no moving parts and is backed by a three-year warranty (30GB model has a two-year warranty), free technical support and legendary Kingston reliability.
- mSATA interface - fully compliant with industry standard, easy to fit, guaranteed to work
- NAND Flash memory based - shock-resistant with low power consumption
- Supports Intel's SRT - combines capacity advantage of HDD with performance improvements of SSD in dual-storage configuration
- Supports SMART - monitors the status of your drive
- Supports TRIM - maintains maximum performance on compatible operating systems
- Guaranteed - three-year warranty (two-year warranty on 30GB), free technical support
