Personal data protection with automatic cloud backup.
The DataTraveler Locker+ G3 offers USB 3.0 speeds and a sleek durable metal casing with a built-in key loop leaving photos, personal documents and other files safe and easy to access.
Kingston's DataTraveler Locker+ G3 password protects and hardware encrypts data giving consumers the best in personal security with USB 3.0 speed. The DTLPG3 boasts higher speeds, with read speeds up to 135 Mbps and write speeds up to 40 Mbps. All the security is built in with no application installation required making this drive very secure and easy to use.
Hardware encryption -- the best in personal security to keep your data safe
Superior password protection -- user sets a password to prevent unauthorised access
Versatile -- works interchangeably between Mac OS X and Windows systems
Secure -- drive locks down and reformats after 10 invalid login attempts
Stylish -- durable metal casing with built-in key loop
Optional cloud backup -- access data stored on DataTraveler Locker+ G3 from your personal cloud storage
Put a lock on your personal data with Kingston's DataTraveler® Locker+ G3. It's a safe and convenient way to secure receipts, bank statements and other sensitive documents with hardware encryption and password protection for a double layer of data security. The drive locks down and reformats after 10 failed login attempts, so users can rest assured that their data is safe even if the drive is lost or stolen.
DataTraveler Locker+ G3 offers automatic USBtoCloud™ by ClevX™ backup as an optional feature. Users can chose to automatically back up data from their DataTraveler Locker+ G3 to Google Drive™, OneDrive (Microsoft®) or Dropbox, so if the drive is lost or stolen, their data is in a safe place.
Its USB 3.0 interface delivers speeds of up to 135MB/s read, approximately 2-3 times the speed of the previous generation, to secure files faster.
DataTraveler Locker+ G3 is easy for anyone to set up and easy to use, with no application installation required; all the software and security needed is built in. It works on both Windows systems and Macs so users can access files from multiple systems, without installing a program on every computer used.
It features a durable metal casing to protect the drive from drops, bumps and knocks plus its built-in key loop makes it convenient to take your data anywhere. The cap fits on the back of the drive so it won't get lost.
DataTraveler Locker+ G3 is covered by a five-year warranty, free technical support and legendary Kingston® reliability.
