Simply insert your tablet into the form-fitting, soft-lined case, which has cutouts for all the tablet's ports and inputs so you can stay connected, plus the kickstand so you can use it on a desk or table.
Add a keyboard
Get additional productivity with the optional HP Travel or Advanced Keyboards, which are fully functional with the tablet in the case.
Be comfortable
Carry the case by hand with integrated, removable hand strap or the included shoulder strap.
World-class support
Rest easy with a one-year limited warranty.
HP Protective Case - notebook shell case
Notebook shell case
Location
Upper
Product Material
Polyurethane, polycarbonate
30.6 cm x 1.46 cm x 21.96 cm
298 g
Notebook Compatibility
12"
Removable shoulder strap, adjustable shoulder strap, camera lens cutout, removable hand strap, port cut-outs, logo cutout
Carrying Strap
Hand strap, shoulder carrying strap
1-year warranty
HP Elite x2 1012 G1
Notebook shell case
Location
Upper
Product Material
30.6 cm
1.46 cm
21.96 cm
298 g
12"
