Easy setup. Simple management. Preinstalled with HP ThinPro operating system this all-inclusive access device is designed to provide a single console interface for dashboard access to all local resources making setup straightforward.
HP easy tools takes the guess work out of thin client setup by streamlining configuration and management applications into easy-to-follow screens that help you choose the right configurations for your environment. HP easy tools utilities include HP EZ Update which delivers automatic image updates, low bandwidth add-ons and configuration changes to like devices and HP Device Manager which simplifies visibility and control in more complex network environments.
PC productivity, flexibility
Connect to the latest in display technology with native dual-digital monitor support or connect to an analog monitor using the included DVI-I to VGA adapter. Standard configurations include 6 USB 2.0 ports, legacy ports, and an HP-exclusive power cord retention slot. You'll experience traditional PC performance and multimedia playback while using less electricity. Energy star qualified configurations help reduce power consumption.
HP Easy Tools, HP Client Automation, HP Device Manager
5.8 cm x 21.6 cm x 21 cm
1.36 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Thin client
Recommended Use
Small business, corporate business
Product Form Factor
Tower
Built-in Devices
Speaker
Processor / Chipset
CPU
VIA Nano U3500
Clock Speed
1 GHz
CPU Qty
1
Max CPU Qty
1
Chipset Type
VIA VX900
Cache Memory
Installed Size
1 MB
Cache Per Processor
1 MB
RAM
Installed Size
2 GB
DDR3 SDRAM
SO-DIMM 204-pin
Hard Drive
Flash
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
VIA ChromotionHD 2.0 Shared Video Memory (UMA)
Video Interfaces
VGA, DVI
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Integrated
Remote Management Protocol
Telnet, SSH
Wake on LAN (WoL), DHCP support
Slots
SO-DIMM 204-pin
6 x USB 2.0 , 1 x serial , 1 x parallel , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x DVI-D , 1 x DVI-I
DVI-VGA adapter
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
FCC Class B certified, VCCI, GS, CB, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03
HP Smart Buy
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
HP ThinPro
Software
