Put more of your content front and center on the HP P224 21.5-inch Monitor. The stylishly modern and sleek profile design delivers essential presentation features and advanced connectivity at a remarkable price point.
Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply.
Find your sweet spot
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
Complete the picture
Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
Responsibly made
Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT Silver registered, and low halogen display.
Divide and conquer
Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
HP P224 - LED monitor - Full HD (1080p) - 21.5" - Smart Buy
With stand - width: 48.85 cm - depth: 18.1 cm - height: 37.1 cm - weight: 3 kg , Without stand - width: 48.85 cm - depth: 4.01 cm - height: 29.32 cm - weight: 2.5 kg
