Help keep your notebook safe in the office and high-traffic areas by tethering it to a secure surface with the HP Master Keyed Cable Lock 10mm, designed specifically for ultra-thin profile notebooks.
Help keep your notebook safe in the office and high-traffic areas by tethering it to a secure surface with the HP Master Keyed Cable Lock 10 mm, designed specifically for ultra-thin profile notebooks.
Loop and lock
Wrap the 6 ft (1.83 m) vinyl-coated, galvanized steel cable around any secure object and attach to your notebook. Insert the master key into the lock and turn clockwise 90 degrees for a great IT manager solution.
Room to move
The cable head swivels 360 degrees to help you position the cable as needed before you lock.
