Print, scan and copy with proven reliability using the cheapest compact wireless laser multifunction printer from HP. Achieve professional quality and performance you expect.
Outstanding reliable quality without compromise
Easily print high-quality documents and with the reliability you expect from the leader in laser printing. Print directly from the start with a pre-installed cassette and an intuitive LED panel. HP Auto-On / Auto-Off technology helps to save energy.
Maximum productivity for business in compact format
Stay productive. Quickly and easily print, scan and copy documents with an efficient, compact laser multifunction printer designed to fit on small workspaces. This multifunction printer from HP provides high-quality results with HP toner cartridges.
The well-connected multifunction printer to match your work style
Provides consistent results that you can trust. Manage jobs from your mobile device, with or without a network. With mobile printing options, you can produce high-quality printing from virtually anywhere.
