PC ports. Minus the PC. Plug in the reader, pop in an SD card*, and easily transfer the files you need to and from your HP ElitePad. Then pack and go when you're ready to disconnect.
HP SD Card Reader - card reader - HP ElitePad docking connector
Card reader
Supported Memory Cards
MultiMediaCard, SD Memory Card
Host Interface
ElitePad 1000 G2, 900 G1
Card reader
Host Interface
3.4 mm
4.6 mm
0.9 mm
12.8 g
Memory Card
(max)
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, FCC Part 15 B, EMC, RoHS, EN 61000, KC
