Be a master at multi-tasking with HP EliteDisplay E242 61 cm (24") Monitor, which delivers Full HD resolution, TCO Edge Certified comfort features, and an extra-large screen for all of your work.
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
Reduce power consumption and help lower costs
Get an intelligent, energy-efficient design that is ENERGY STAR certified, EPEAT Gold registered, and meets TCO Certified Edge requirements.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software.
Make it yours
Customize a complete solution with HP accessories designed and tested to work with your display.
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI (HDCP) , DisplayPort (HDCP) , VGA
Mechanical
Display Position Adjustments
Tilt Angle
-5/+25
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x VGA cable , 1 x DisplayPort cable , 1 x USB cable
Compatible with Windows 7
Without stand - width: 56.22 cm - depth: 5 cm - height: 37.74 cm - weight: 4.2 kg , With stand - width: 56.22 cm - depth: 18.9 cm - height: 51.9 cm - weight: 6.23 kg
