Go big or go home with the HP DreamColor Z32x 80,01 cm (31.5") UHD Display, HP's largest UHD 4K display, which delivers a staggering 8 million pixels and 4K resolution and has award- winning HP DreamColor technology built right in.
Work comfortably with adjustable tilt, height adjustment, and swivel settings. Use pivot rotation for portrait or landscape views when using multiple displays. An integrated HP Quick Release Bracket supports wall mounting.
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software.
Designed with the environment in mind
Be a better consumer with a display that has environmentally responsible components.
HP DreamColor Z32x Professional - LED monitor - 4K - 31.5"
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
Picture in picture, picture by picture, HDCP, DreamColor, Mobile High-Definition Link (MHL) 2.0, Colour gamut BT.709, arsenic-free glass
73.71 cm x 24.54 cm x 61.38 cm - with stand
10.8 kg
MHL / HDMI (HDCP) , HDMI (HDCP) , DisplayPort (HDCP) , Mini DisplayPort , 4 x USB 3.0 downstream , Audio line-out , USB 3.0 upstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, 1 USB 3.0 charging port, low halogen
1 x DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x USB cable - 1.8 m
Backlight Life
40,000 hours
Compatible with Windows 7
With stand - width: 73.71 cm - depth: 24.55 cm - height: 61.38 cm - weight: 10.8 kg , Without stand - width: 73.71 cm - depth: 7.01 cm - height: 43.46 cm - weight: 7.8 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years - on-site - response time: next business day
