Plug one end of the adapter into your HP Mobile Workstation or HP Docking Station and the other end into a standard outlet. The included 4.5mm to 7.4mm smart cable allows you to carry one adapter for new and legacy platforms.
Take it with you
Power up wherever you work. The compact, reliable adapter fits easily in your notebook's carrying case and is 50% lighter than its previous generation model.
Worry-free charging
Get an adapter that detects and regulates the correct electrical current for your HP Mobile Workstation or HP Docking Station.
World-class support
Rest easy with a one-year limited warranty.
HP Smart AC Adapter - power adapter - 150 Watt
Power adapter - external
320 g
English / United Kingdom
Power Capacity
150 Watt
15.3 cm x 6.6 cm x 2.2 cm
EliteBook 1050 G1 Notebook; ZBook 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15u G3 Mobile Workstation, 15v G5 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation
HP EliteBook 1050 G1 Notebook , HP ZBook 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15u G3 Mobile Workstation, 15v G5 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation
