The HP Mobile Print Accessory helps mobile device users print wirelessly without searching for a printer or accessing a company network. Get touch-to-print wireless printing from NFC-capable devices or through a peer-to-peer connection.
Make wireless direct printing easy for everyone in your office.Get secure wireless printing from smartphones, tablets and laptops, using a wireless direct connection – no need for a router or network connection.Compatible with up to 5 simultaneous users.
Get convenient mobile printing at a touch
Simply touch your mobile device to the accessory and start printing.Enable touch-to-print convenience from NFC-capable mobile devices.
Enjoy simple and fast installation
Get up and running fast with easy USB plug-and-play installation.Connecting mobile device users to your office printers or MFPs is as simple as attaching this HP Mobile Print Accessory through a USB port.
Go mobile and stay secure
Keep your network out of reach: The HP Mobile Print Accessory supports wireless direct printing and touch-to-print from mobile devices.Peer-to-peer connection allows mobile users to print without accessing the company network.
HP 1200w NFC/Wireless Mobile Print Accessory - direct print adapter
Direct print adapter
External
67.5 cm x 111.2 cm x 27.5 cm
80 g
802.11b/g/n, NFC
Frequency Band
2.4 GHz
RAM
128 MB
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Android 3.2 (Honeycomb), Apple iOS 4.2 or later, Android 4.0.3, Windows 8 (32/64 bits), Android 4.1 (Jelly Bean), Android 4.0.4, Android 4.2 (Jelly Bean), Android 2.3.3 or later, Android 4.3 (Jelly Bean)
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B
1 x USB cable
Encryption Algorithm
WPA2
CSA, UL, GOST, CCIB, EN 60950, EN 61000-3-2, EN55022, ICES-003, NOM, IEC 60950, EN 61000-3-3, EN55024, FCC Part 15.247, RSS-210, PSB, FCC CFR47 Part 15 B, LVD, EN 300 328, EN 301 489-17
External
2.5 Watt
Software Included
HP Embedded Web Server, HP ePrint
