Retain the screen's crystal clarity and touchscreen interactivity through a filter that inhibits a direct view of your content from everyone but you and resists scratches and glare.
Easy application
Use the included adhesive strips for easy application, and reuse as needed if you swap between devices.
No cutting or resizing required
Get a precise fit for your screen with a filter that doesn't interrupt access to your webcam and microphone.
Award-winning support
Rest easy with a one-year parts replacement limited warranty.
