- For the installation of TFT/LCD/LED monitors with a screen diagonal of up to 66 cm (26")
- Integrated high-performance pneumatic spring for vertical, fully adjustable orientation
- 360° rotation for horizontal or vertical orientation
- Swivel arms for maximum rotation
- The retaining system keeps your workplace tidy and allows you to work ergonomically
- Cable manager provides organisation and necessary strain relief
- Swivel range on 3 hinges: up to 360°
- Swivel range up to 180°
- Inclinable +/- 90°
- Supports all VESA standards up to 100x100
- Table fastening with clamping screw (table top thickness up to max. 10 cm) or drill-secured mounting
Note for Consumers:
To ensure that the holder is height adjustable, a minimum supported load of around 1.5 kg is required.
Technical Details:
- Maximum Load: 5 kg
- Model: Monitor Arm
- Monitor Fixation Standart: VESA incl. Adapter Plate
- Rotation Range: 360 °
- Tilt +/-: 90 / 90 °
- Adjustable Distance: Yes
- Max. Monitor Size: 66 cm
- VESA Standard: 100 x 100 mm
- Width x Depth x Height: 11,5 x 52,2 x 11,2 cm
- Colour: Black
- For Monitors: 26"
- For a Table Top Thickness of: 10 cm
