You shouldn’t have to choose between looking great and keeping your phone safe when you buy a case. And with Identity, you don’t.
Griffin's All Clear Identity cases get both their good looks and their protective abilities from a skillful layering of materials that deflect impacts and vibration while letting the beauty of your iPhone show through.
Identity cases protect your phone from four-foot drops. The dual-material frame is made from color-keyed shock-absorbent rubber bonded to a hard polycarbonate plastic frame. Swap any Identity frame and back plate to create your own unique look, thanks to Identity’s interchangeable design.
