Mount your GoPro to handlebars, seatposts, ski poles and more. The hinged, non-slip design easily clamps to different mounting locations or secures to a pole or pipe to create a handheld boom. The mounting buckle lets you move your GoPro between mounts on the move, and the base features 360° rotation to help achieve the perfect angle for every shot. Fits 9 to 35 mm (0.35 to 1.4 in) diameter tubes.
- Hinged, non-slip design sets up in seconds and clamps to any 0.35 to 1.4 in (9 to 35 mm) diameter tube
- Rotating base features 360° rotation with 16 secure positions, ensuring the perfect angle and allowing rapid changes in perspective for more dynamic footage
- The mounting buckle lets users move their camera between mounts on the move, enabling fast and easy changes in perspective
- Durable construction prevents slipping and breaking and minimises vibration and camera shake
- No loose parts to drop or lose
What’s Included
- Handlebar/Seatpost/Pole Mount
- Large Rubber Insert
- Small Rubber Insert
- Vertical Mounting Buckle
- Long Thumb Screw
Compatibility
