Google Pixel Buds - Life sounds amazing.
Brilliant sound, all around.
With custom-designed 12 mm dynamic speaker drivers, Google Pixel Buds deliver rich, high-quality audio. Adaptive Sound adjusts the volume for you as you move between quiet and noisy environments. And beamforming mics and voice accelerometers help make your calls crystal clear, even in loud and windy conditions.
Stay comfortable. And aware.
Ergonomically designed to fit just about everyone, Google Pixel Buds come with three eartip sizes and a stabilizer arc, so they stay in place and create a gentle seal for sound. A spatial vent lets you keep aware of what’s going on around you and reduces that plugged-ear feeling.
Get help here, there, and everywhere.
Talk to the Google Assistant right from your Google Pixel Buds. Play your favorite music, continue your podcast, send a message, and get step-by-step directions from Google Maps. Just say "Hey Google," or press and hold the earbud. Google Pixel Buds also give you real-time translation. So whether you’re ordering dinner in Seoul or visiting your multilingual family for the holidays, you can communicate easily.
Cut the cord.
Google Pixel Buds quickly and easily connect to Android, iOS, or any Bluetooth® 4.0+ device. And they pair with Pixel in just one tap. Get up to 5 hours of listening time with one charge and up to 24 hours using the wireless charging case. And if you misplace your earbuds, use Find My Device to locate the earbuds by making them ring.
Tech Specs
Compatibility Requirements:
Pairs with any Bluetooth® 4.0+ device, including Android, iOS, tablets, and laptops
Full access to features requires Google Account, Assistant-enabled companion phone running Android 6.0 or newer, and an internet connection. For minimum OS and hardware requirements and available Google Assistant languages, go to g.co/pixelbuds/help
Sweat and Water Resistant:
Pixel Buds have a water protection rating of IPX4 under IEC standard 60529. Water resistance is not a permanent condition and may be compromised by normal wear and tear, repair, disassembly or damage.
Wireless connectivity (each earbud):
Bluetooth 5.0
Audio (each earbud):
Custom-designed 12 mm dynamic speaker driver
Passive noise reduction
Spatial vent for in-ear pressure reduction and spatial awareness
Voice (each earbud):
Dual beamforming microphones
Voice detecting accelerometer
Sensors (each earbud):
Capacitive touch sensors for music, calls, and Assistant controls
Dual IR proximity sensors for in-ear detection to play and pause automatically
Motion-detecting accelerometer and gyroscope
Wireless Charging Case:
USB-C charging port
Works with compatible Qi-certified chargers
Hall Effect sensor for case close detection
Battery:
Earbuds: Up to 5 hours of listening time and up to 2.5 hours of talk time
Earbuds with wireless charging case: Up to 24 hours of listening time and up to 12 hours of talk time
10-minute charge of earbuds in the wireless charging case delivers up to 2 hours of listening time and up to 1 hour of talk time
Approximate battery life based on music playback and talk, with other features disabled. Charging times are approximate. Use of other features will decrease battery life. Testing conducted on pre-production hardware and software. Battery life depends on device, features enabled, usage, environment and many other factors. Actual results may vary.
Dimensions:
Earbuds (each): 20.5 x 19.5 x 18.2 mm (excl. eartip and stabilizer arc)
Wireless charging case: 63 x 47 x 25 mm
Weight:
Earbuds (each): 5.3 g
Wireless charging case: 56.1 g without earbuds, 66.7 g with earbuds
What’s in the Box:
Earbuds
Eartips with 3 size options: small, medium (attached to earbuds), large
USB-C to USB-A charging cable
Quick Start Guide
