- Powered by NVIDIA DLSS 3, ultra-efficient Ada Lovelace arch, and full ray tracing
- 4th Generation Tensor Cores: Up to 4x performance with DLSS 3 vs. brute-force rendering
- 3rd Generation RT Cores: Up to 2X ray tracing performance
- Powered by GeForce RTX™ 4060 Ti (8GB)
- Integrated with 8GB GDDR6 128bit memory interface
- WINDFORCE cooling system
- Protection back plate
The WINDFORCE cooling system features two 90 mm unique blade fans, alternate spinning, 3 composite copper heat pipes directly touch the GPU, 3D active fans and Screen cooling, which together provide high efficiency heat dissipation.
Reduce the turbulence of adjacent fans and increase airflow pressure.
The 3D active fan provides semi-passive cooling, and the fans will remain off when the GPU is in a low load or low power game.
The airflow is split by the triangular fan edge, and guided smoothly through the 3D stripe curve on the fan surface.
Graphene nano lubricant can extend the life of sleeve bearing fan by 2.1 times, close to the life of double ball bearing, and is quieter.
Extended heatsink allows air to pass through, providing better heat dissipation.
The shape of the pure copper heat pipe maximizes the direct contact area with the GPU. The heat pipe also covers the VRAM through a metal plate contact to ensure proper cooling.
The back plate not only provides an aesthetical shape, but also enhances the structure of the graphics card to provide complete protection.
Ultra durable certified high-grade metal chokes, lower ESR solid capacitors, 2 oz copper PCB, and lower RDS(on) MOSFETs, plus over-temperature design to deliver superior performance and longer system life.
Fully automated production process ensures top quality of the circuit boards and eliminates sharp protrusions of the solder connectors seen on the conventional PCB surface. This friendly design prevents your hands from getting cut or inadvertently damaging components when making your build.
GIGABYTE offers the good power supply solutions for your graphics cards.
- Gigabyte GeForce RTX 4060 Ti WINDFORCE OC 8G - graphics card - GeForce RTX 4060 Ti - 8 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4060 Ti - up to
- Memory
- 8 GB GDDR6
- Memory Speed
- 18 Gbps
- Core Clock
- 2550 MHz
- CUDA Cores
- 4352
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort (version 1.4a) , 2 x HDMI
- API Supported
- DirectX 12 Ultimate, OpenGL 4.6
- 4.1 cm x 20.1 cm x 12 cm
- 3-year warranty
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2550 MHz
- CUDA Cores
- 4352
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- 3D Active Fan, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, composite copper heat pipes, Gigabyte Alternate Spinning, GIGABYTE WINDFORCE cooling design, Heat Pipe Direct Touch technology, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA DLSS 3, NVIDIA Reflex, Nvidia Studio, screen cooling, Graphene Nano Lubricant
- Size
- 8 GB
- Technology
- GDDR6 SDRAM
- Memory Speed
- 18 Gbps
- Bus Width
- 128-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- Software Included
- Gigabyte Control Center
- 4.1 cm
- 20.1 cm
- 12 cm
- Limited warranty - 3 years
