- NVIDIA GeForce GT 430 GPU (Fermi GF 108)
- 40 nm, No external power connector needed
- Core/ Mem clock: 730/1800 MHz (std 700/1800) 1 GB DDR3 Memory
- 10% performance better than generic HD 5570
- New fan sink: GIGABYTE Low profile Dual Fan
- Native Golden Plated HDMI
- Powered by NVIDIA GeForce GT 430 GPU
- 96 Stream Processors
- Microsoft DirectX 11 and OpenGL 3.2 support
- Supports PCI Express 2.0 interface
- Features Dual Link DVI-I/ D-Sub/ HDMI
- Supports NVIDIA Pure Video HD Technology
- Support NVIDIA PhysX / CUDA Technology
- 400 Watt or greater power supply recommended
- GPU GeForce GT 430
- Core Clock 730 MHz (std 700 MHz)
- Memory Clock 1800 MHz
- Shader Clock 1460 MHz
- Memory Size 1 GB DDR3
- Bus Type PCI Express 2.0
- Memory Bus 128-bit
- Stream Processors: 96
- Memory type 64Mx16
- DirectX 11 Yes
- DVI Port DVI-I (Support Dual-link DVI-I)
- HDMI Yes
- D-sub Yes
- HDCP Yes
- Video in No
- 3DMark Vantage Extreme: X 1888
- 3DMark Vantage Performance: P 4615
Faster clocks, double the transistor density of earlier 40 nm technology. 40nm technology helped make GT 430 series products the most advanced GPUs ever highest clocks speeds, incredible feature integration, full performance and precision all the time, and ability to take advantage of future, higher-speed memories.
Shader Model 5.0 adds support for indexed temporaries which can be quite useful for certain tasks. Regular direct temporary access is preferable is most cases. One reason is that indexed temporaries are hard to optimize. The shader optimizer may not be able to identify optimizations across indexed accesses that could otherwise have been detected. Furthermore, indexed temporaries tend to increase register pressure a lot.
Now you are ready for the most demanding graphics applications thanks to PCI Express 2.0 support, which allows up to twice the throughput of current PCI Express cards.
High-Bandwidth Digital Content Protection (HDCP) is a form of copy protection technology designed to prevent transmission of non-encrypted high-definition content as it travels across DVI or HDMI digital connections.
High Definition Multimedia Interface (HDMI) is a interface standard for consumer electronics devices that combines HDCP-protected digital video and audio into a single, consumer-friendly connector.
Available on HD DVDs and Blu-ray Discs, high-definition movies are bringing an exciting new video experience to PC users. NVIDIA PureVideo HD technology lets you enjoy cinematic-quality HD DVD and Blu-ray movies with low CPU utilization and power consumption, allowing higher quality movie playback and picture clarity. PureVideo HD technology provides a combination of powerful hardware acceleration, content security, and integration with movie players, plus all the features found in PureVideo.
NVIDIA CUDA is a general purpose parallel computing architecture that leverages the parallel compute engine in NVIDIA graphics processing units (GPUs) to solve many complex computational problems. It unlocks the power of the hundreds of cores in your NVIDIA GeForce GPU to accelerate some of the most performance hungry computing applications. From video transcoding to "Folding home", CUDA technology already adopted by thousands of programmers to speed up intensive computing applications.
NVIDIA PhysX is the next big thing in gaming! Delivering physics in games is no easy task. It's an extremely compute-intensive environment based on a unique set of physics algorithms that require tremendous amounts of simultaneous mathematical and logical calculations. The best way to get real-time physics, such as explosions that cause dust and debris, characters with life-like motion or cloth that drapes and tears naturally is with an NVIDIA PhysX-ready GeForce processor.
- Graphics Processor
- NVIDIA GeForce GTS 430
- Memory Size
- 1 GB
- Interface
- PCI Express 2.0
- Digital Output
- Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
- Graphics Processor Manufacturer
- NVIDIA
- Core Clock
- 730 MHz
