Looking for an affordable option to bring disc burning in house? The Microboards QD series 10 recorder DVD/CD duplicator is configured for your throughput requirements. The QD-DVD-1210 DVD Duplicator is perfectly suited to organizations that need to deliver small runs on demand or need to have in house control of their content. Ease of use and a compact footprint make the QD-DVD-1210 DVD duplicator suited for the front office or practically anywhere in the studio. One button copying gives the user the ability to make ten copies at a time at the highest recording speed available. Use it standalone (without connecting to a PC) or connect it to your PC for easy mastering over the USB port with the included recording software! The QD-DVD-1210 supports DVD+R and DVD-R, and can copy DVD Video or data. In addition, the QD-DVD-1210 supports all of the most popular CD recording formats, including audio, data, and more. Even dual-layer DVD discs can be copied on this versatile DVD duplicator.
Scream through your production with blistering fast 48x CD-R/20x DVD-R/+R recorders and an easy-to-use four-button interface. The QD towers make disc duplication an easy task, even if you're not a "computer wizard".
