The Node 804 is a micro ATX chassis which focuses on cooling performance and maximum configurability, all packed in an interesting form factor with Scandinavian elegant design.
The dual chamber layout separates hot running components from the cooler ones and allows for unrestricted airflow over the motherboard, processor and graphics card.
The case comes with three excellent 120 mm fans but can be upgraded with several additional fans if needed. The flexibility of this case really gives the users the possibility to create their optimal system build.
