8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
65 ppm (mono) / 65 ppm (colour)
Max Document Size
216 mm x 356 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8, Microsoft Windows Server 2012 x64 Edition
EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 356 mm
Automatic
80 sheets
USB 2.0 - Type B
1 x USB cable
Compatible with Windows 7
Environmental Standards
ENERGY STAR Certified
Software Included
EPSON Scan, EPSON Document Capture Pro
