Back
Printers & Multifunction
Epson TM-U220PB Receipt Printer
Quicklinx:
8GP7WS00
Mfr#:
C31C517007
Back
1ST IMPACT PACKAGED PRINTER * PS, NES; Parallel; Epson Cool White (ECW); Power Supply.
Easy-to-use impact printer
If you need a hard worker that's easy to use and versatile, this is the ideal impact receipt printer.
Epson TM U220PB - receipt printer - two-colour (monochrome) - dot-matrix
Printer Type
Receipt printer - dot-matrix - 9 pin - two-colour (monochrome)
2.5 kg
Max Media Size
Roll (7.6cm)
Max Media Size (Custom)
76 mm
Print Speed
Up to 6 lines/sec - max speed
Max Resolution (B&W)
17.8 cpi
Cutter
Parallel
Language Simulation
EPSON ESC/POS
Media Type
Receipt paper
Total Media Capacity
1 roll
Enclosure Colour
Cool white
1-year warranty
16 cm x 24.8 cm x 13.9 cm
Printer Type
Enclosure Colour
Cool white
Printer
Print Speed
Up to 6 lines/sec - max speed - 16 cpi
Built-in Devices
Cutter
Wired
Parallel
17.8 cpi
Language Simulation
EPSON ESC/POS
Character Sizes (mm)
1.2 x 3.1 mm, 1.6 x 3.1 mm
Columns
33, 35, 40, 42
Auto Cutter
Repeating Printing
1 copy
Media Handling
Media Type
Receipt paper
Max Media Size
Roll (7.6cm)
76 mm
Media Sizes
Roll (7 cm), Roll (7.6cm), Roll (5.8 cm)
Media Thickness Range
0.06 mm - 0.085 mm
Roll Maximum Outer Diameter
83 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (7.6cm)
Expansion Slots
1 x expansion slot
1 x parallel
Mounting Kit
Optional
MTBF
180,000 hour(s)
Wall mountable
FCC Class A certified, CSA, UL, TUV, EN 60950, VCCI Class A ITE, EN55024, EN55022 Class B, AS/NZ 3548 Class B
Power adapter - external
31 Watt
Power Consumption Stand by / Sleep
2.2 Watt
Limited warranty - 1 year
50 °C
10 - 90%
16 cm
24.8 cm
13.9 cm
2.5 kg
