This Mi Home Radiator Valve requires the Mi, Home Gateway to work, available seperately. Search QL CZFF and see bundles to buy together
Make your home smarter with Mi Home Radiator Valves
- Take control of your heating, lighting and electrical devices wherever you are
- FREE iOS and Android App, plus browser interface
- Easy to fit to existing TRV body - just unscrew your existing TRV head - no plumber required
- 1 Year battery life, dual thermostat, ultra quiet motor
- Communicates current and target temperatures to the Mi, Home Gateway, as well as battery status
Mi, Home Smart Radiator Valves provide automatic control and zoning of your heating system. Each valve can be programmed by time and temperature, so you only heat the rooms you want to the temperature you specify. Use Geofencing and IFTTT to fully automate your heating. A true whole-of house Smart Home
Box Contains
- 1 x Mi, Home Smart Radiator Valves
- 2 X AA batteries
- 1 spacer rings
- 2 adapter collars
- Instructions
