Lithium-ion batteries are longer lived than conventional batteries and do not require replacement as often. This 9-cell Lithium-ion battery from Dell helps you power up your system for business trips and vacations. With a capacity of 90 WHr this battery lets you work seamlessly when you are on the move.
