Take your presentations wherever you choose with the Dell Mobile Projector M115HD, the ideal travel companion for the mobile professional.
Small and bright
You want the ultimate in brightness from your projector. Light up the room with the M115HD, featuring dazzlingly bright, colorful and crystal-clear projection.
Total connectivity
Accept no limits when it comes to bringing media to your presentations. The M115HD features a remarkable amount of connectivity, giving you a wide range of media options to choose from. More than just a projector, the M115HD is truly a portable media hub for home and office.
Dell Mobile Projector M115HD - DLP projector
DLP projector - 720p
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
450 ANSI lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
Video Input
RGB
Supported Memory Cards
microSD
Storage Capacity
1 GB Flash
Video Modes
480p, 720p, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
52 Watt
10.53 cm x 10.4 cm x 3.65 cm
360 g
1-year warranty
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
450 ANSI lumens
Contrast Ratio
10000:1
Image Size
76 cm - 203 cm
Projection Distance
0.97 m - 2.58 m
Throw Ratio
1.5:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
LED
Bulb life cycle
Controls & Adjustments
Keystone correction
High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, MobiShow technology, Mercury-free illumination technology, upgradable firmware
Lens
Focus Type
Manual
Lens Aperture
F/2.0
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI
Video Modes
microSD
Media Player
Storage Capacity
1 GB Flash
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x microSD
1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x VGA - 24 pin universal I/O , 1 x VGA (on supplied cable)
Carrying case
1 x VGA cable
Security Features
52 Watt
Power Consumption Stand by
0.5 Watt
10.53 cm
10.4 cm
3.65 cm
360 g
Limited warranty - lamp - 1 year , Limited warranty - 1 year
