The Dell 17 monitor E1715S is your smart choice for reliability and essential features that can help drive productivity. Add the E1715S to your workplace for a great viewing experience in just about any setting.
The E1715S offers HD quality viewing, easy connectivity and compatibility with legacy custom applications.
Responsible design
The E1715S minimizes power consumption with an efficient LED backlight and PowerNap technology.
A great fit
This compact, 5:4 aspect ratio monitor can fit into smaller spaces while still maintaining compatibility with software requiring a 5:4 display ratio.
Simple connections
Simplify connections to laptop and desktop PCs with VGA and DisplayPort connectors.
Tilt adjustment
Tilt the screen up to 5.5° forward or 22° backward for optimal viewing comfort.
Dell E1715S - E Series - LED monitor - 17"
LED-backlit LCD monitor - 17"
Energy Class
Class D
Power Consumption (On mode)
9 W
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Colour Gamut
85% (CIE 1976)
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
37.45 cm x 16.55 cm x 38.95 cm
United Kingdom
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
CEL
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
17"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
85% (CIE 1976)
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
PowerNap
37.45 cm x 16.55 cm x 38.95 cm - with stand
VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-5.5/+22
VESA Mounting Interface
100 x 100 mm
Stand
CEL
United Kingdom
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
9 W
9 kWh/1000h
Power Consumption (Typical)
11 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 37.45 cm - depth: 16.55 cm - height: 38.95 cm , Without stand - width: 37.45 cm - depth: 4.65 cm - height: 30.69 cm - weight: 2.08 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Limited warranty - advance parts replacement - 3 years
