For memory-dependant server applications such as virtualization - cloud computing - Big Data - and HPC - Crucial DDR4 server memory is an ideal way to increase memory bandwidth and capacity.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial memory significantly increases memory bandwidth, allowing your system to handle more data at once. As memory technology matures, bandwidths are expected to achieve amazing speeds. To maximize bandwidth, Crucial memory is optimized for next-gen platforms, that support four channel memory.
More energy efficient
Get better performance - using less power. Operating at lower power, Crucial memory consumes less voltage. Crucial modules also contain other efficiency features, for an outstanding overall power reduction.
