The Corsair VS650 is a great choice if you’re building a home or office system with lower power demands, but you still demand the compatibility and reliability that Corsair is known for.
The VS650 delivers a guaranteed 650 Watts of continuous power. With 0.99 Active Power Factor correction, you get the peace of mind from knowing that your components are protected from uneven power delivery. And a dedicated single +12V rail saves you from the hassle of balancing your components across multiple power cables.
Low noise, high efficiency
The 120mm fan is thermally controlled, so it only spins at maximum speed when it's pushed hard - and even at full load, it's pretty quiet. Smart design features like this are why VS650 offers up to 85% efficiency. Your PC system will generate less heat, and you'll enjoy lower energy bills.
Sophisticated design
The black powder-coated enclosure and the black-sleeved cables give any system a polished look. You're building a PC, not a battleship, and with the VS650 you can avoid that look of unpainted steel that you'll find on so many entry-level power supplies.
CORSAIR VS Series VS650 - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V
80 PLUS Certification
80 PLUS
1.5 kg
United Kingdom
Input Voltage
AC 200-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 50 A , -12V - 0.3 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V , 4 x 15 pin Serial ATA power , 4 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Cooling System
120 mm fan
Cable ties, mounting kit
Black powder coat
15 cm x 14 cm x 8.6 cm
3-year warranty
ATX12V 2.3/ EPS12V
PSU Form Factor
ATX
Black powder coat
United Kingdom
Input Voltage
AC 200-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
Efficiency
85%
80 PLUS
MTBF
100,000 hours
Cooling System
120 mm fan
Sleeved cables, over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, non-modular
FCC Class B certified, TUV, C-Tick, CB, CCC, cTUVus
