The M65 PRO RGB is a competition-grade FPS gaming mouse with the technology you need to win, the flexibility to make it your own, and the build quality to last. The high-accuracy 12000 DPI sensor provides pixel-precise tracking and advanced surface calibration support, and the aircraft-grade aluminum frame gives it low weight and high durability. Use the advanced weight tuning system to set the center of gravity to match your play style, and harness the power of CUE for advanced button configuration, macro programming, and three-zone RGB backlighting customization.
