The unconventional design of Carbide Series Air 540 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way. The included custom Air Series AF140L intake and exhaust fans provide great airflow performance at lower noise levels than typical case fans. And, you can mount up to six 120mm or five 140mm fans, with 280mm top radiator support and room for a 360mm radiator on the front panel. Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. The tinted, oversized flush-mount side window lets you show off your work.
- Dual-chamber Direct Airflow Pathâ„¢ design for outstanding cooling potential
- Clever, space-saving design still offers lots of internal volume
- Includes three High Performance Air Series AF140L fans for better, quieter cooling
- Tons of expansion room for high performance air cooling and liquid cooling
- Full side panel window
- Front dust filter
- Black interior
- Cable routing cutouts with rubber grommets
- CPU cutout in motherboard tray for easy CPU cooler swap-out
- Dual front USB 3.0 ports with internal connector
- Headphone, Microphone front ports
- Eight expansion slots for quad GPU installations
- Fan Mount Locations
- Front: 2 x 140mm (included), 3 x 120mm (pre-spaced for radiators)
- Top: 2 x 140mm or 2 x 120mm (pre-spaced for radiators)
- Rear: 1 x 140mm (included) or 1 x 120mm
- Dual 3.5" hot swap bays
- Four 2.5" tool-free SSD drive cages
- Maximum GPU Length 320mm
- Maximum CPU Cooler Height 170mm
- Maximum PSU length 200mm
- Dimensions 415mm x 332mm x 458mm
- Material Steel and plastic
- Color Black
- Model CC-9011030-WW
- Drive Bays (x2) 5.25" tool-free (x2) 3.5"/2.5" tool-free Drive Caddies (Hot Swap) (x4) 2.5" tool-free SSD cage
- Cooling (x2) AF140L 140mm Intake fans (x1) AF140L 140mm Exhaust fan
- Expansion Slots 8
- Motherboard E-ATX, ATX, Micro ATX, Mini ITX
- Front I/O (x2) USB 3.0 (x1) Headphone, (x1) Mic
- Power Supply ATX (not included)
