The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability.
Key Features
- Maximize your system memory capacity for ultimate performance
- Guaranteed to work on all dual channel Intel and AMD platforms
- XMS heat spreader
- World famous Corsair reliability and performance
Package Contents
- Designed for use with all DDR3 motherboards with two memory channels
- Warranty: Lifetime
- Size: 8GB Kit (2 x 4GB)
- Performance Profile: XMP
- Fan Included: No
- Heat Spreader: XMS
- Memory Configuration: Dual Channel Memory
- Type: DDR3
- Package - Memory Pin: 240
- Package - Memory Format: DIMM
- Tested Voltage: 1.65
- SPD Voltage: 1.5
- Speed Rating: PC3-12800 (1600MHz)
- SPD Speed 1333MHz
- Tested Speed 1600Mhz
- Tested Latency 9-9-9-24
- SPD Latency9-9-9-24
