CS Series Modular power supplies are ideal for basic desktop systems where low energy use, low noise, and simple installation are essential. 80 PLUS Gold efficiency reduces operating cost and excess heat. Flat, sleeved black modular cables with clearly-marked connectors make installation fast and straightforward, with good-looking results.
- Modular cabling system lets you use only the cables you need
- 850W Continuous power with 80 PLUS Gold certified efficiency for low noise and lower power bills
- Built and tested to strict standards for trouble-free installation and smooth operation
- Over-voltage and over-power protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
- Extra long fully-sleeved cables support full tower chassis.
Box Contains
1 x CS850W PSU and Cables
