Beautifully simple and engineered to perform: the Crystal 460X has two-panel tempered glass, Direct Airflow cooling technology, is compact, expandable, and with advanced fan, you can customize to your heart's content.
Crystal 460X was engineered to pack all the performance and expandability you need into a beautifully modern and compact case design. Put your build on display through beautiful two-panel tempered glass and keep it all running cool and quiet with Direct Airflow technology.
Liquid cooling capable
With room for front, top, and rear radiators, you can choose to quiet down your GPU and CPU with liquid coolers just about wherever you want to.
Direct Airflow Path
Drive cages are moved up and out of the path of cool air from the front intake fans and high-temperature components.
Minimal setup
With tool-free drive installation and three-point dust filter access, the Corsair Crystal 460X is easy to build - and even easier to keep clean. You'll spend less time on setup and maintenance, and more time enjoying your PC.
CORSAIR Crystal Series 460X - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Front dust filter, Direct Airflow Path design, tool-free drive holder, Liquid Cooling Ready
No power supply (ATX)
22 cm x 44 cm x 46.4 cm
7.97 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
5
Product Material
Steel
Cooling System
Front: 120 mm fan x 1 / intake / 2 x 140 mm fan or 3 x 120 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
200 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
